Nissan pickup won't start
SWILSON
My 1994 Nissan pickup with 134,000 miles and standard transmission does nothing when I try to start it. I have replaced the starter twice (the parts store tested the last one before I put it on), replaced the battery, and had the alternator tested. When I turn the key it does nothing at all. I can roll start it but that's it. The clutch interlock relay is engaging. Any suggestions?
Mar 5, 2006 at 5:29 AM
FISHERMAN
  • 937 POSTS
did you check for spark on the spark plugs?
how about gas on your lines?
its your switch working properly?
the dash lights are on in the ignition position of your switch?
Mar 6, 2006 at 7:32 AM
DAVEGB
its the relay near bat double plug wack it good trust me
May 19, 2006 at 3:10 PM
