nissan pick up not running correct
HOUSE3571
1991 nissan 4 cyl. 115,000 miles. Car was running fine then went sour. Feels like not on all cylinders. Truck starts fine but not enough power to move. Oil looks fine, changed the plugs wires no help. Truck will idle a little rough with some sputter and a little white smoke(just a trace). Does this sound terminal. Thanks
Dec 20, 2006 at 6:11 AM
  • 75,988 POSTS
when was the last major tuned-up done?
Dec 21, 2006 at 10:07 PM
HOUSE3571
i coulnt tell ya, i had it about two years, i put new wires, plugs on a bout a month ago and nothing changed? Thanks
Dec 22, 2006 at 1:52 AM
  • 75,988 POSTS
Go back in the spark plugs and inspect for fouling and when you have some funds change the cap and rotor,fuel filter PCV valve and check the ignition timing and its fuel pressure to include exhaust restriction for no power
Is this a KA24 engine
HTH-Merry Christmas
Dec 22, 2006 at 7:06 AM
