Milky oil
BIGROB1111
I have just redone the head on my 85 nissan 720 hardbody pick up. The head was machined and cleaned up. But i have milky oil which i have heard that it is antifreeze getting into the oil. Is this correct and if so how do i fix it? Thanks
Oct 14, 2007 at 6:20 AM
FISHERMAN
  • 937 POSTS
[quote:f6584f78cb="bigrob1111"]I have just redone the head on my 85 nissan 720 hardbody pick up. The head was machined and cleaned up. But i have milky oil which i have heard that it is antifreeze getting into the oil. Is this correct and if so how do i fix it? Thanks[/quote:f6584f78cb]
Hello !!
Well.. did you flush and change the oil after you fix the head?
or its the "old" oil ?
If its the "old" coolant-oil...do a "Quick flush" with a quality product and follow the printed instructions, change the filter and oil and do the oil change every 2k miles two times then at recommended intervals every 3k miles..
also check your cooling system for oil on it...
(if you find oil in the cooling system let me know and I will tell you on the procedure to drain fill and purge your cooling system)
let us know if you have a question..
good Luck!
(thanks a lot for your Donation!)
Oct 15, 2007 at 2:40 AM
