Nissan Truck Accessories Dead Until Revved
VICTORIAPARAS
My son (Kyle) recently purchased this truck 161,000 miles. The vehicle sat unused for about one and a half to two years. The battery was drained of course and we thought it needed a new alternator. The truck cranks and runs great. The problem is that the tail lights, dash gauges, dome lights, radio and A/C do not work when just the key is turned on or when the truck is just cranked. After the engine is revved to about 5000 rpm every thing comes on and works fine until the truck is turned off again. The headlights and wind shield wipers work fine. We put in a new alternator (even though the old alternator tested out good, we were told to replace it anyway) and the problem persists. We intend to take the truck to a mechanic this evening to get some sort of diagnoses, but he had no idea what he might be looking at and charges by the hour to find the problem. So, if you have any starting points or suggestions we would greatly appreciate it.
Nov 29, 2006 at 1:57 AM
  • 55,673 POSTS
Try checking the headlight control switch and/or the turn signal switch. Nissan had a problem with headlight switches.
Nov 29, 2006 at 4:34 AM
VICTORIAPARAS
The headlights were fine. Apparently the alternator wire was not a heavy enough gauge to carry the load. The fellows at Pep Boys found the problem and changed the wire and now every thing works fine.
Thanks,
Victoria and Kyle
Nov 30, 2006 at 7:55 AM
  • 55,673 POSTS
Cool, glad it is fixed.
Nov 30, 2006 at 8:30 AM
Suggested Repair
Replace the undersized alternator wire with a heavier-gauge wire that can carry the accessory load. If the problem remains, also check the headlight control switch and turn-signal switch.
Conversation Summary
A high-mileage Nissan truck that had sat unused had working headlights and wipers, but the tail lights, gauges, dome lights, radio, and A/C stayed off until the engine was revved to about 5000 rpm. A new alternator did not fix it. An expert suggested checking the headlight and turn-signal switches. The owner later reported that the alternator wire was too light for the load; replacing it with a heavier-gauge wire restored normal operation.
