95 Nissan Pick up starter problems
1995 NISSAN TRUCK
SEALS97
I have a 1995 nissan pick up, with 130,000 on the truck but only 5,000 on the engine and starter. The problem is when i go to turn the key, nothing happens, no clicking no nothing. However i can push start it. Does anyone know what is wrong and how to fix it? Thank you for any/all help.
Apr 20, 2007 at 3:25 PM
[quote:bf5a59c295="SEALs97"]I have a 1995 nissan pick up, with 130,000 on the truck but only 5,000 on the engine and starter. The problem is when i go to turn the key, nothing happens, no clicking no nothing. However i can push start it. Does anyone know what is wrong and how to fix it? Thank you for any/all help.[/quote:bf5a59c295]
Battery okay and connections clean and tight?
If its automatic-could be the ignition switch/neutral safety switch/inhibitor/solenoid and starter
Manual-ignition switch,clutch switch,solenoid and starter.
Apr 20, 2007 at 5:20 PM
SEALS97
Yes the battery is 2 months old, i tried charging it to see if that was the problem. It is a manual transmition. How would i check if its one of those problems?
Apr 20, 2007 at 11:30 PM
