idle adjust screw is stripped
APENA
Recently, my truck was idling bad and idle was fluctuating from 1600 to ~ 1800 RPM. SPECs state that it should be 750 +- 50 RPM. When I went to adjust the idle during a tune-up, according to the service manual, I could not since the idle screw seemed to be "stuck" and somewhat "stripped".
This was probably done during the last tune-up more than a year ago and that mechanic shop is no longer in business.
Can I "drill" the screw out with a screw extractor? Or--is this screw set so that it will NOT screw out? I hope I can fix this since a new throttle body is quite expensive.[img:217e4918c4]http://www.2carpros.com/forum/automotive_pictures/115045_IdleSpeedAdjust_01_1.jpg[/img:217e4918c4]
Nov 8, 2007 at 6:17 AM
  • 75,988 POSTS
Here is a video of how you can remove a stripped screw to fix the problems.
https://youtu.be/YDt5OUIZTs0
If this doesn't work you will need to replace the throttle body here is a guide.
https://www.2carpros.com/articles/how-a-throttle-body-works
Nov 10, 2007 at 1:56 AM
ALLCEAYT
Engine Mechanical problem
1989 Nissan Truck 4 cyl Two Wheel Drive Manual
I need to lower my idle on my truck and cannot do in on the carb.
Jan 21, 2019 at 12:05 PM (Merged)
  • 75,988 POSTS
Try adjusting the fast idle cam and choke opening using the repair manual and then adjust the curb idle speed.
