Recently, my truck was idling bad and idle was fluctuating from 1600 to ~ 1800 RPM. SPECs state that it should be 750 +- 50 RPM. When I went to adjust the idle during a tune-up, according to the service manual, I could not since the idle screw seemed to be "stuck" and somewhat "stripped".
This was probably done during the last tune-up more than a year ago and that mechanic shop is no longer in business.
Can I "drill" the screw out with a screw extractor? Or--is this screw set so that it will NOT screw out? I hope I can fix this since a new throttle body is quite expensive.[img:217e4918c4]http://www.2carpros.com/forum/automotive_pictures/115045_IdleSpeedAdjust_01_1.jpg[/img:217e4918c4]
Nov 8, 2007 at 6:17 AM
