91 Nissan pickup truck4x4 king
1991 NISSAN TRUCK
SPIRITWALKER
it is a 4 cylinder and my question is on the transmission cross members there are two weights on it that just bolt up What are they there for? and my second question is that when I let off the clutch in first it gerks for a little while and it continues to gerk until you get speed built up in 3rd or 4th gear could it be the pressure plate or is it possible that it could be the motor mount because it feels like a dry foam instead of a hard rubber(dont know if this is normal)?
Sep 7, 2007 at 4:00 PM
MERLIN2021
  • 17,250 POSTS
those are vibration dampers. Leave em there. Jerking can be clutch related...worn warped, who knows!
See if the motor moves excessivly whe jacked...if the mount is split you'll see it seperate.
Sep 8, 2007 at 12:42 AM
