2005 Nissan Truck Valve Job
2005 NISSAN TRUCK
54,000 MILES • V8 • 4WD • AUTOMATIC
LILLTITAN
I bought a used Titan and 3 weeks after I got it, it started to smoke a lot at start up. I have done engine flushes, oil changes, even tried the ATF trick, all with no results. I am being told that I am going to have to have the valves totally redone. How much is a fair price for this type of job?
May 8, 2008 at 9:52 AM
  • 31,937 POSTS
Hi there,
This is very hard to determine as you just don't know how much damage is to be repaired, i would ring around and get a price on a change over re-co head. this will give you a bench mark for what will be a max cost for the job. Also be aware that with older engines if you repair the head and improve the compressions you can stress the old rings to a point where they will start for fail and oil usage is a problem again..
Mark (mhpautos)
May 8, 2008 at 12:17 PM
