2005 Nissan Truck Connecting rod through engine
2005 NISSAN TRUCK
50,997 MILES • 4 CYL • 4WD • MANUAL
AQUARIUS07
My truck recently had no4 con rod blow through the engine.
The engine recently did 18000 miles without servicing would this affect the con rods ?
The vehicle was bought new & had been serviced regularly up to that point.
Jan 30, 2008 at 4:18 AM
You missed 6 oil changes the oil is dirty that dirt/debris made it to no.4 bearing block off the flow-it got overheated and welded to the crankshaft journal and it threw the rod.
Jan 30, 2008 at 7:21 AM
AQUARIUS07
Thank you for your reply.
According to the nissan recommendation the engine is to be serviced every 6000 miles/6months, therefore missing only 2 services.
When the vehicle was last serviced it had a major overhaul ( Nov 07 ) this was to compensate. The engine blew 23rd Jan 08.
In between the services oil was checked regularly & replaced when required. The dealer was made aware that it had been a while in between services would they have not changed the oil ?
Jan 30, 2008 at 10:10 PM
