2004 Nissan Truck engine noise
75,000 MILES • V8 • 2WD • AUTOMATIC
2CARPROS CHRIS
  • 16 POSTS
VALVETRIAN IS ACTING WIERD MAKING NOISE WHAT SHOULD I DO?
Apr 29, 2008 at 11:06 AM
  • 31,937 POSTS
Hi there,
You may have a low oil pressure problem, as the valve train is often the first thing to suffer if oil pressure is down, Have the pressure tested with a master gauge, this will give a true indication as to the oil pressure, with this information your mechanic can make a proper diagnoses.
mark (mhpautos)
Apr 29, 2008 at 11:22 AM
