2002 Nissan Truck Will not continue to run
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
RAYTORRES
I was on the highway, truck stalled. Pulled off the road, was able to restart engine but it coughed and shook. Got it home, now it will not start. Listened for fuel pump, it made the right noise. Any ideas? Need my truck to get to work! Thanks
Mar 29, 2010 at 12:08 PM
  • 75,988 POSTS
Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 29, 2010 at 12:42 PM
