2000 Nissan Truck engine miss
JEMILLER58
Engine Performance problem
2000 Nissan Truck 4 cyl Two Wheel Drive Automatic
engine misses on number 4 cyl on accell when egr is open
Mar 28, 2010 at 6:47 AM
MATHIASO
  • 1,209 POSTS
Hello jemiller58
Check ignition system for problem (coil or plug) that affects Cylinder 4
Fuel delivery component fault that affects only Cylinder 4 (i.e., a contaminated, dirty or sticking fuel injector)
Base engine mechanical fault that affects only Cylinder 4 or air leak in the intake manifold, or in the EGR or PCV system.
Mar 28, 2010 at 8:30 AM
