1997 Nissan Truck Rear Main Seal Replacement
16,900 MILES • 4 CYL • 2WD • AUTOMATIC
METRIC1000
  • 6 POSTS
I removed the old rear seal and as I started to install the new one, I noticed the lip on the end of the crank was about 1/4 inch larger than the surface that the seal rests on. I tried forcing the seal over this lip and damaged the new seal. I know there must be a reasonable answer, but I can't find it. Please help! I am stumped.....
Jun 17, 2008 at 9:41 AM
DOCFIXIT
  • 18,828 POSTS
Place the seal upon the crank lube well first then with a .006 or so feeler run the feeler between the seal lip and crank while pushing it on over lip. Then use appropiate seal driver and your home.
Let me know what happens
Jun 17, 2008 at 9:52 AM
METRIC1000
  • 6 POSTS
[quote:7fbcbd5f09="Docfixit"]Place the seal upon the crank lube well first then with a .006 or so feeler run the feeler between the seal lip and crank while pushing it on over lip. Then use appropiate seal driver and your home.
Let me know what happens[/quote:7fbcbd5f09] I will try it this morning....and let you know how it went.
Jun 17, 2008 at 11:48 PM
