1997 Nissan Truck po301 error code
1997 NISSAN TRUCK
COPIERGUY1
Engine Mechanical problem
1997 Nissan Truck 4 cyl Two Wheel Drive Manual
1197 nissan pickup. blowing black smoke, but not all the time. code reader says po301 error. #1 cylinder misfire. today it started doing it more. i am at a loss. HELP!!!!
Sep 28, 2010 at 4:43 PM
Specific cylinder misfire-start by checking the sparkplug, compression and injector for cyl no.1
Probable causes of an engine running rich are as follows:
1.Excessive fuel pressure can be cause by restricted fuel return line or defective fuel pressure regulator.
2.Defective Oxygen Sensors.
3.Leaking injectors and fuel pressure regulator.
4.Coolant temperature sensor out of calibration.
5.Restricted air intake system.
Sep 28, 2010 at 5:03 PM
