1997 Nissan Truck large vacuum leak
18,073 MILES • 4 CYL • 4WD • MANUAL
GUSWHEEZ
Recently my check engine light came on. A few days later the ABS light came on, then shut off. (the ABS has come on and off a couple of times), then my cruise control light started blinking and quit working, then my A/C yesterday stopped blowing cool air. The light is not coming on for the A/C
I took it in for a diagnostic check
It is saying either "blocked injector", large vacuum leak or MAF sensor fault
My question is: could all these symptoms be related due to a vacuum leak or sensor fault???
May 12, 2009 at 3:53 PM
  • 31,937 POSTS
Hi there,
Can you post the actual codes that were set? this will help me determine the exact cause of your problem.
Mark (mhpautos)
May 12, 2009 at 5:32 PM
GUSWHEEZ
Thanks for your prompt replie.
There was only one code that was set when they ran the diagnostic.
OEM number P0171
May 12, 2009 at 6:30 PM
