1997 Nissan Truck Fuel pump relay is getting signal to cut
1997 NISSAN TRUCK
180,000 MILES • 4 CYL • 4WD • MANUAL
ADAK
My fuel pump is intermittantly cutting out causing missing and killing engine. When this happens dark smoke is noticeable from tail pipe. Will run fine for few miles then reoccurs.
Switched out fuel pump relay but problem remains.
I jumped out the fuel pump relay and engine runs fine. I need to know what could be cutting power to the fuel pump relay.
Sep 5, 2008 at 1:34 AM
Its the ECM that controls the fuel pump relay
Sep 7, 2008 at 7:41 AM
