1997 Nissan Truck Engine lopes at idle, then clears
1997 NISSAN TRUCK
285,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARK3539
My engine has a loping that comes and goes at idle. The engine will slow, then start loping for a minute, then clear up. I found a stuck EGR valve, and replaced it, but the problem is still there. Second engine, probably has about 150000 on it, and trans was rebuilt last year.
Oct 26, 2010 at 2:37 AM
Check the idle air control valve, mass airflow sensor and throttle position sensor
Oct 26, 2010 at 2:56 AM
QTIP24
sounds like the same problem I,m haveing now with a 97 nissan xe 2.4 L KA24E w/manual. where you able to solve your problem?
Jul 25, 2011 at 6:50 PM
