1996 Nissan Truck starting
17,500 MILES • 4 CYL • 2WD • MANUAL
MIKESPIKE
won't start. battery is good. turn key, not a sound. all lights and other elecrtical working. does it have a celenoid? the "saftey" button that engages when you push in the clutch has always been touchy. do these go bad? where is the started located on this model?
Aug 9, 2009 at 7:59 AM
  • 75,988 POSTS
Jumper the clutch interlock switch-don't work check and test or swap the interlock relay and see what happens.
Aug 9, 2009 at 8:17 AM
