1996 Nissan Truck hard starting after warmup
160,000 MILES • 4 CYL • 4WD • MANUAL
FXST
  • 9 POSTS
It starts perfect cold.Ater driven,you go to start it,and it doesnt like to start right up.It sputters,and you have to give it a little gas to coax it to life.This problem just started. the mechanic said he could'nt find any thing wrong,no error codes, when it does start it runs excellent, no idle or performance problems.It is fuel injected(throttle body),so you should'nt need to give it a little gas to start it when its warm right?
Oct 22, 2010 at 11:03 AM
  • 75,988 POSTS
Check the fuel pressure could be losing pressure and causing hard starts
Oct 22, 2010 at 12:51 PM
