1996 Nissan Truck Engines starts to stall out after 20-30 m
1996 NISSAN TRUCK
107,000 MILES • 4 CYL • 4WD • MANUAL
RATB7378
To Technical people,
I have a Nissan Pickup King Cab XE 2.4ltr K? (107kmiles) series.
The Problem:
My truck runs great for about 20 minutes or so, usually on the highway.
then the engine starts to knock out. Weird but it happen when I hit a bump. When it is a
smooth ride it seems to work fine...
I pepper the gas and this kind of brings it back. but not all the time,but continues to die.
Again after the 20 - 30 time period. Short rides there are NO PROBLEMS at ALL..
If it dies it will start right back up again but still same issue.
Come to a stop enging wants to die....
I have replaced wires,plugs distribtor cap/rotor.
I have replaced fuel filter,nothing.
Replace all the belts too......
any ideas.
Brian
ratb7378@hotmail.com
847-849-7378
Truck Specs:
2.4 LTR
Air Conditioning
Power Steering ( I think Assist)
Idles and sounds fine...
Jul 1, 2010 at 12:27 PM
Check the fuel pressure to rule out a failing fuel pump if okay test coil, distributor pick-up coil, ignition control module, cam and crank sensors
Jul 1, 2010 at 7:07 PM
