1996 Nissan Truck engine stall when slowing or stopped
81,000 MILES • 4 CYL • 2WD • AUTOMATIC
BANGORJOHN
Help. Truck starts fine and runs OK until warmed up then it sometimes stalls when stopped in traffic. I believe I hear a chattering noise coming from pasenger side of engine compartment or dash. (Hard to pinpoint) I have replaced fuel filter and added carburator cleanering product to fuel per directions with no positive results. Friend owns a handheld diagnostic device, plug it in with engine ok code present.
Apr 12, 2008 at 2:01 AM
  • 55,682 POSTS
It sounds like the engine has a vacuum leak, this condition will make the engine stall. Please inspect all vacuum feed lines, plus has the engine had a major tune up lately, when the engine warms up it can cause the ignition wires to cross fire, causing the engine to stall.
Apr 14, 2008 at 3:50 AM
