1995 Nissan Truck starter
175,000 MILES • 4 CYL • 2WD • MANUAL
ALTERRIEN
truck only sometime will not start. can hear clicking when i turn key, dash light come on, battery is new tow month old. have had problem for a few years. after playing with key for several time starter will engage. but how i have to push truck to start only sometimes. i was thinking starter siloder???
Mar 26, 2010 at 8:09 AM
BLUELIGHTNIN6
  • 16,542 POSTS
could be failing starter or could be failing ignition switch. you can have the starter tested at most local auto part stores for free of charge. if it tests good then may want to look at checking out the ignition switch.
Mar 26, 2010 at 9:08 AM
