1995 Nissan Truck lower ball joints
1995 NISSAN TRUCK
138,000 MILES • 4 CYL • 4WD • MANUAL
CHRISWOLPERT
I'm having one heck of a time breaking loose the lower ball joints. I've been hammering away with a pickle fork and with no success. Should I be using a "press kit?" If so, do I have enough room to apply a press kit? What other suggestions do you have for breaking loose the ball joints? Also, in order to remove the lower ball joint once it's broken loose, do I have to remove the drive shaft boot?
Oct 12, 2010 at 5:44 PM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_727.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2780.jpg
Oct 13, 2010 at 6:15 AM
