1995 Nissan Truck Headlights will not come on
1995 NISSAN TRUCK
70,000 MILES • 4 CYL • 2WD • MANUAL
OKIESINGER
New battery was installed and cables were crossed, fusable link at battery was fried obvious. It was replaced and cables switched back Ignition worked, and everything else came back ok. But headlights will not come on. Is there another link some where we don't know about. Or do you know what else to check?
Thanks
Mike
Jan 30, 2008 at 7:23 AM
Check fuse no.49 and 50 15amp in the fuse and fusible link box,left front of engine compartment
Also check the head light relays-the right H/L relay is located at left relay box behind left headlamp and the left H/L relay is at right relay box right side of engine compartment
Relays/Fuses checks out -replace the combination switch.
Both lights has its on seperate ground point which is the black wire on the headlight connector
Jan 30, 2008 at 7:41 AM
