1995 Nissan Truck BRAKE LIGHT SWITCH
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
JS7220
BRAKE LIGHTS STAY ON WHEN ENGINE AND SWITCHES ARE TURNED OFF,I REPLACED SWITCH AND ITS ADJUSTED,LIGHTS ARE STILL ON,WHAT IS MY NEXT STEP TO TROUBLE SHOOT AND FIX PROBLEM?
Sep 25, 2010 at 9:12 AM
  • 75,988 POSTS
Sound like the wiring for the brake is shorted together
The red and black is shorted to the green and yellow wires-do this remove the brake wiring conector and do a continuity -if you have a reading its shorted together causing the light to come on
Sep 25, 2010 at 9:49 AM
