1995 Nissan Truck brake light stays on with engine turned o
1995 NISSAN TRUCK
127,647 MILES • 4 CYL • 2WD • AUTOMATIC
NISSSANPROB
MEMBER
1 POST
how do i get brake lights to turn off?
Apr 18, 2010 at 9:19 AM
✓ASE Certified Mechanic
Either you adjust the brake switch or replace it if unable to-
Apr 21, 2010 at 1:46 PM
DJMJ86
MEMBER
i have same problem with my 95 nissan truck, brake lights wont turn off but the engine is off and all lightsa n switches are off?? its so weird... what could it be and where is the brake light switch??
Aug 19, 2010 at 11:02 PM
Follow the brake pedal arm till it meets the brake support bracket you'll find it there
Aug 19, 2010 at 11:10 PM
DJMJ86
MEMBER
then just replace it??? or wiggle it until it works or what? It just started doing this its kinda odd..
Aug 19, 2010 at 11:39 PM
Could be a broken pieces to it-try adjusting it unable to-replace it-
Aug 19, 2010 at 11:46 PM
