1995 Nissan Truck bad alternator
1995 NISSAN TRUCK
143,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNCANIA
my brake light and battery light stays on.when i turned my signal lights on my radio flashed with the signal lights and my dashboard lights went dim.i made it home and when i cut it off it was dragging and would not start only making a clicking noise.what does this sound like?
Dec 4, 2008 at 12:18 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:0be04b25b5="johncania"]Electrical problem
1995 Nissan Truck 4 cyl Two Wheel Drive Automatic 143000 miles
my brake light and battery light stays on.when i turned my signal lights on my radio flashed with the signal lights and my dashboard lights went dim.i made it home and when i cut it off it was dragging and would not start only making a clicking noise.what does this sound like?[/quote:0be04b25b5]
Sounds like your alternator. If you can remove it and take it by your local auto parts store and have then test it. You will also need to charge up your battery.
Post finding here in forum.....
Jan 22, 2019 at 4:49 AM
