1995 Nissan Truck A/C Problem
1995 NISSAN TRUCK
167,000 MILES • 4 CYL • 2WD • MANUAL
BHUNTER
I have a 95 nissan pickup 2.41 litre and noticed the air conditioner compressor runs continuously whether the air conditioner switch is in the on or off position. When I pull the fuse the compressor clutch will disengage. When I pulled the a/c relay fuse under the hood the compressor didn’t turn off. Can you tell me what the problem may be. Thanks.,
Feb 15, 2010 at 1:57 AM
BHUNTER
[quote:d281a081bc="bhunter"]Air Conditioning problem
1995 Nissan Truck 4 cyl Two Wheel Drive Manual 167000 miles
I have a 95 nissan pickup 2.41 litre and noticed the air conditioner compressor runs continuously whether the air conditioner switch is in the on or off position. When I pull the fuse the compressor clutch will disengage. When I pulled the a/c relay fuse under the hood the compressor didn’t turn off. Can you tell me what the problem may be. Thanks.,[/quote:d281a081bc]
Feb 15, 2010 at 1:58 AM
