1995 Nissan Truck ac help
1995 NISSAN TRUCK
RTRIP95897
  • 7 POSTS
Air Conditioning problem
1995 Nissan Truck 4 cyl Two Wheel Drive Manual
i have a 1995 nissan pickup the ac want kick in, but it will if you streight wire it so the compresor is good and it gets cold, i replaced the main switch inside and the thermo switch behind dash, the dual presure switch has contnuity so i think it is ok any idea?
Jul 9, 2010 at 7:34 AM
Check the fuse and wiring, low pressure switch, double check the high and low pressures with a manifold gauges-also the AC relay
Jul 9, 2010 at 8:52 AM
RTRIP95897
  • 7 POSTS
the fuse and relay are good and i bypassed the low presure switch and it still want come on, i dont have a guage but when i straight wire it it cools down too about 36 degrees inside, so i dont now what to do . thanks for replying i appershate the help.
Jul 9, 2010 at 9:24 AM
Check and test the thermal protector its in between the clutch and the AC relay
Jul 9, 2010 at 3:02 PM
RTRIP95897
  • 7 POSTS
i replaced the thermo control switch that was located in the box with the cooling unit coils,maybe it was a bad new part?i mite need to check it again?thanks iam not a mechanic but i pride myself on fixing my on stuff and this is about to get me!
Jul 10, 2010 at 4:58 AM
