1994 Nissan Truck Tail lights, signal lights
164,000 MILES • 4 CYL • 2WD • MANUAL
MRANDWHATSO
The tail lights nor the signal lights are working, I checked the fuses and each individual light bulb, they are all good. What should I check next.
Apr 1, 2010 at 4:04 AM
TWOSTEPPER
  • 42 POSTS
I'd check voltage and ground at the bulb socket. Did you use a voltage tester on the applicable fuse circuits?
Apr 1, 2010 at 4:42 AM
