1994 Nissan Truck PCV VALVE
144,000 MILES • 4 CYL • 2WD • MANUAL
SONNYISLA
  • 5 POSTS
I AM WONDERING IF YOU COULD TELL ME THE LOCATION OF MY PCV VALVE AND THE THERMOSTAT. I HAVENT REPLACED IT SINCE I OWN THIS TRUCK AND OF WHEN SHOULD I REPLACED IT HOW MANY MILES OR YEARS INTERVAL, HOPED TO HEAR FROM YOU SOONEST, THANK YOU....
Jan 10, 2009 at 4:30 PM
BLUELIGHTNIN6
  • 16,542 POSTS
The thermostat is installed on the inlet side of the water pump. The PCV valve should be under the intake manifold, near oil filter.
Unless you are having issues with these components, they do not need replaced. Only replace them if they fail.
Thanks for using 2carpros.com!
Jan 10, 2009 at 4:55 PM
