1994 Nissan Truck nissan 12 valve 2400 getting to much gas
1994 NISSAN TRUCK
13,000 MILES • 4 CYL • 4WD • MANUAL
TONY1960
i have a 1994 nissan pickup that i just changed motors in,i am having problem with it getting hot and not starting again till it cools down...I thinks its getting to much gas but cannot figure out why...i have changed all injectors,all new vacumm lines,new plugs,i have tried about everything i know to try,,,really need some expert opinion..
Jul 13, 2010 at 10:53 AM
,i am having problem with it getting hot and not starting again Next time it dies out don't wait for nothing do below immediately to establish if its a fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jul 13, 2010 at 11:17 AM
