1994 Nissan Truck fuel problem
1994 NISSAN TRUCK
13,000 MILES • 4 CYL • 4WD • MANUAL
TONY1960
when its cold it will start up and idle perfect for a few minutes then it gets warm and sputters and quits running.from there it needs to cool off before it will start again.We just changed engines and this is the problem we are having..we have changed injectors , throttle body, fuel regulator,spark plugs,plug wires ,cleared return line to gas tankchanged fule filter..I am thinking it maybe getting to much gas, but thats just my thought..really need help on this one.
Jul 13, 2010 at 11:32 AM
Hi tony1960, Welcome to 2carpros and TY for the donation
Hook up a fuel pressure gauge and monitor the fuel pressure to rule out the fuel pump it will show up as sore thumb before it'll stall if okay
Further check and test the power transistor, resistor/condenser, ignition coil ,and camshaft position sensor in the distributor
Might want to do below next time it stalls out don't wait, to catch it if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jul 13, 2010 at 12:22 PM
