1994 Nissan Truck engine lobes or drops coming to a stop at
172,000 MILES • 4 CYL • 2WD • MANUAL
CPOWELL
My truck will no longer idle. I havepower when going down the road but if I come to a stop it stalls and dies. I noticed a change in the idle 3 weeks ago when I came to a stop at the bottom of a hill. The engine was idling fine then all of a sudden it dropped and then has continuely gotten worse as the weeks have passed. Listening to the engine you can hear a hissing sound. I have already tried soapy water to see if I can find any vacuum leaks-none have been spotted. The sound seems to be coming from the intake side of the engine. The truck has had a basic tune up and oil change, but the symptoms are getting worse. Do you think this could possibly be an intake gasket issue?
Jul 25, 2010 at 2:39 AM
  • 75,988 POSTS
Clean out the IACV-AAC valve, and EGR valve also test the throttle position sensor and aiflow meter.
Jul 25, 2010 at 8:19 AM
