1994 Nissan Truck Brake Lights
1994 NISSAN TRUCK
85,000 MILES • 4 CYL • 2WD • MANUAL
EKIM
I had to replace the gas tank filler neck and gas cap after the old one was torn off when a rear tire lost it's tread. When I finished the brake lights were on.
Ican't get them to go out. I've tried everything I could think of short of replacing the brake light switch at the brake peddal. Could the brake light problem be related to replacing the filler neck??????
Sep 24, 2008 at 9:20 AM
Check the brake switch if it has power to it-No power check fuse-if okay -adjust or replace the switch-still no pwer at the light-trace wire form switch to lights-
Sep 24, 2008 at 9:25 AM
