1993 Nissan Truck Transmission noise
1993 NISSAN TRUCK
GENE GARNER
Transmission problem
1993 Nissan Truck 6 cyl Four Wheel Drive Manual
When the truck is idling out of gear there is low rumbling sound with no vibration, but when you push the clutch pedal in the noise goes away. The cluth was replaced recently and it has made the noise ever since.
Jun 8, 2008 at 2:44 PM
  • 31,937 POSTS
Hi there,
This will be a faulty spigot bearing, thrust bearing or front gear box bearing. your mechanic will be able to diagnose the correct fault by listening and doing a few simple tests.
Mark (mhpautos)
Jun 8, 2008 at 6:11 PM
