1993 Nissan Truck over heating
303,921 MILES • 4 CYL • 2WD • AUTOMATIC
IOWABALLER32
I was wondering what could cause my truck to be over heating. I changed my waterpump ,thermostat ,and head gasket. my radiator is not clogged , it is free flowing, and hoses are free flowing. So i was wondering if you woudl know any other reason it woudl be over heating?
Oct 16, 2008 at 12:30 PM
  • 75,988 POSTS
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: ,Pressure test the Rad. cap,Clogged radiator,air lock in the cooling system ,Fan clutch,Radiator electrical fan,collaspe hoses,water pump.
Oct 16, 2008 at 3:07 PM
