1993 Nissan Truck cant get the clutch to bleed
1993 NISSAN TRUCK
160,000 MILES • 4 CYL • 4WD • MANUAL
JEREMY2805
i just had to rebuild the bottom end on my nissan and for some strange reason the slave cylinder blew out i replaced it and bleed it and couldnt get it to bleed so i replaced the master cylinder still wouldnt bleed all that is left is the damper and i dont know what it is for and it still wont bleed
Mar 13, 2008 at 12:29 PM
MASTERTECHTIM
  • 4,750 POSTS
jeremy is the bleeder on the slave cylinder on the top of it or the bottom. i find that some times the bleeder is on the bottom and you need to remove the slave and put it upside down and then bleed it, then reinstall it. hope this helps
Mar 13, 2008 at 12:32 PM
