1993 Nissan Truck Brake Lights stay on
1993 NISSAN TRUCK
110,000 MILES • 4 CYL • 2WD • MANUAL
CHUC KJH
One day last week, I turned off the truck and my brake lights stayed on. The only way I can get them turned off is to remove the fuse. I can't find any shorts in the wiring harness in the light assembly.
Feb 2, 2008 at 10:57 AM
MASTERTECHTIM
  • 4,750 POSTS
adjust and or replace your brake light switch. hope this helps
Feb 2, 2008 at 11:00 AM
CHUC KJH
Is this part available at a retail parts supply? Where is the switch located?
And thanks for the help!
Feb 2, 2008 at 11:03 AM
MASTERTECHTIM
  • 4,750 POSTS
yes, very inexpensive and is located at the brake pedal. look up under dash and when you press the pedal you will see the switch, it has a rod that pops out of it when the pedal is pressed, this is what is supposed to activate the lights.
Feb 2, 2008 at 11:06 AM
CHUC KJH
[quote:f2a0395fce="mastertechtim"]yes, very inexpensive and is located at the brake pedal. look up under dash and when you press the pedal you will see the switch, it has a rod that pops out of it when the pedal is pressed, this is what is supposed to activate the lights.[/quote:f2a0395fce]
Thanks again! I'll check it out tomorrow during the day. :)
Feb 2, 2008 at 11:12 AM
