1993 Nissan Truck brake lights are not working...
1993 NISSAN TRUCK
199,000 MILES • 4 CYL • FWD • MANUAL
CHARMS9000
My brake lights only work when the head lights are off. Any ideas?
Aug 28, 2008 at 8:04 AM
It sounds like you have a short circuit between the tail and brake circuit-To find out remove both bulbs on the back and do a continuity test between the brake and tail circuit any readings indicates that the wires are touching-inspect bulbs socket for corrosion that may be causing the short too.
Aug 28, 2008 at 8:21 AM
