When first starting, and for the first minute or so of idling, the engine is smooth. After that, it develops a miss and it will misfire about every 2-5 seconds at idle. Engine also has a pretty substantial miss when lightly on the throttle or when coasting.
I checked spark plug gapping and the wires are in good shape. I recently replaced many of the vacuum lines, but will test with vacuum pump. I also checked the amount of play in the EGR valve when the engine was off and the diaphragm moves fairly easily.
What should I do next?
Apr 13, 2010 at 8:56 AM
