i have a 1600c petrol running thirsty. had carb adjustment and new air cleaner spark plugs etc
May 27, 2008 at 6:42 PM
✓Experienced Mechanic
Hi there,
you will have to check all the basics, don't think that because something has been adjusted it is correct. get an exhaust reading and check for high HC's the power valve may be leaking check all tune items and make sure the float level in the carby is correct.
