My truck will start up well for about nine or ten times, then it won't. I turn the key and get a buzz or click noise. If push started it starts right up. Have had starter checked and it is ok. Battery is also good. Which leaves the ignition. Have had it out and cleaned it and put back together, but same thing happens. It will start for awhile, then not. After push starting it, if I turn it off and try starting again, it starts right up several times in a row.
Aug 30, 2009 at 8:18 AM
