1990 Nissan Truck Fan
220,000 MILES • 4 CYL • 2WD • MANUAL
NISSANTRK
When I start the engine there is a noise that sounds like the fan fins vibrating excessively. After the engine is warmed up the sound goes away.
I had the timing chain, gems, guides, and tensioner replaced in 2002 and the belts serviced in 2006.
Apr 27, 2008 at 12:44 PM
  • 75,988 POSTS
Check the power steering pump fluid and the AC compressor-You have an electric fan it shouldn't be coming from there
Apr 27, 2008 at 1:03 PM
