1990 Nissan Truck Clutch
1990 NISSAN TRUCK
278,000 MILES • 4 CYL • 2WD • MANUAL
GEORGIAHURT
Put new slave cyclilnder in truck, not bleeding correctly. Have some pressure. and has fluid in lines ok. Air is getting in somehow trying to ajust the clutch.
Feb 18, 2009 at 4:44 AM
If there's no actual leakage best double check the clutch master cylinder if it has an internal leak with cups/seals.
Feb 18, 2009 at 6:50 AM
