1989 Nissan Truck problem I can't figure out
SVEN_39553
  • 1989 NISSAN TRUCK
Engine Mechanical problem
1989 Nissan Truck 4 cyl Two Wheel Drive Manual
i have a 1989 nissan I bought and when I was goin down the road it just kinda sputtered and shut off. I checked the distributor and the plugs and everything to do with all the ignition. I checked to see if I was gettin fuel and its gettin what it needs. I got spark I got fuel and yet it doesnt even want to act like its turning over at all. Any info that I could get would be great cause im not the best mechanic in the world and I dont want to take anymore apart than I have to cause from what I found out about this engine its a japanese motor that was put in as a switch of motors before I bought the truck.
Thursday, January 29th, 2009 AT 5:52 AM
BMRFIXIT
  • 19,053 POSTS
If you have spark at the plugs
and have fuel and check the fuel pressure
the next step is a compression test
remove all spark plugs and do a compression test
check timing
Thursday, January 29th, 2009 AT 6:05 AM
