1989 Nissan Truck no start
ELECTRIC2012
Engine Performance problem
1989 Nissan Truck 4 cyl Two Wheel Drive Manual
engine quite while warming up.
wont restart
check for codes-none
no spark- tested dist with modus- looked ok
all test lead to power transistors which i replaced- no change- replace cap and rotor - no change
any help please
Feb 26, 2010 at 8:27 AM
  • 75,988 POSTS
Have you tested the crank angle sensor? if not do so if it turns out defective -you need a new distributor assy.
Also did you check and test the coil primary and secondary winding resistances
Feb 26, 2010 at 8:42 PM
