1989 Nissan Truck High rpm, delayed shifting
1989 NISSAN TRUCK
RLLHENRY
  • 5 POSTS
Transmission problem
1989 Nissan D21 Pickup 6 cyl-3.0L Two Wheel Drive Automatic Transmission - L4N71B 89000 miles
The transmission is shifting throiugh all four gears but, at very high RPM's which causes the vehicle to jerk as the shift is completed. The fluid and the filter has been recently changed and no leaks appear.
Mar 20, 2008 at 4:37 PM
MASTERTECHTIM
  • 4,750 POSTS
WHAT MODEL TRUCK AND WHAT SIZE ENGINE? GET BACK TO ME AND ILL RESEARCH IT.
Mar 21, 2008 at 11:03 AM
RLLHENRY
  • 5 POSTS
[quote:edfe60f517="mastertechtim"]WHAT MODEL TRUCK AND WHAT SIZE ENGINE? GET BACK TO ME AND ILL RESEARCH IT.[/quote:edfe60f517] 1989 D21 Nissan Pickup, 3.0L - Automatic (type) L4N71B
Mar 21, 2008 at 11:52 AM
MASTERTECHTIM
  • 4,750 POSTS
i found that there is a bulletin for this only when cold, you replace the fluid with a special fluid, but this is only when cold. also the other thing i found is the governor(controls shift points and is located in the tailshaft housing.) i would suggest having a transmission repair shop road test for you. i was hoping i was going to find a vacuum controlled modulator valve, but you dont have one. hope this helps
Mar 21, 2008 at 12:01 PM
MASTERTECHTIM
  • 4,750 POSTS
https://images.2carpros.com/forum/automotive_pictures/139033_gov_1.jpg
Mar 21, 2008 at 12:13 PM
RLLHENRY
  • 5 POSTS
I,m going to try replacing the modulator because i found tranny fluid in the tube.
Mar 21, 2008 at 12:14 PM
RLLHENRY
  • 5 POSTS
I Checked the modulator that was located on the drivers side of the transmission, A little bugger to get to. Modulator Okay. I then followed the vacuum line to the intake and realized that the vacuum line was deteriorated and needed to be replaced. What can you expect for such an old girl. Runs sweet. Next time when you guys receive a donation, try researching the problem a little closer.
Mar 22, 2008 at 3:11 PM
MASTERTECHTIM
  • 4,750 POSTS
noone is perfect. for as many questions we answer each day, we all try our best. if you read my post one of the first things i suggested was the modulator valve but the information you gave me showed the transmission to have a governor not a modulator valve. im not claiming i have a crystal ball and can see your truck. i did take the time to look up your vehicle and research your problem. there is only so much we can do. i did give you a honest effort.
Mar 22, 2008 at 6:48 PM
RLLHENRY
  • 5 POSTS
Just a quick note on the site that I found my information for the transmission. USATRANSDOCTOR.COM
Mar 23, 2008 at 8:21 AM
