1988 Nissan Truck Nissan d21 z24
MIGEL
  • 1988 NISSAN TRUCK
  • 4 CYL
  • 4WD
  • MANUAL
  • 160,000 MILES
I have a 1988 nissan truck but when im driving it starts to miss fire and stall the.
help please
Thursday, April 29th, 2010 AT 2:32 PM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Thursday, April 29th, 2010 AT 2:37 PM
No the coils don't need chassis ground
Friday, April 30th, 2010 AT 12:30 AM
JIMMYJAMES
These vehicles are semi notorious for intermittent mechanicaly sticking injectors. This will cause surge, missfire, stalling ect. This is somewhat maddening. It is worse when the engine is fully warm on a hot day. There is no easy way to diagnose this. Prosses of elimination. I personally have the same problem I have 25 yrs. Master auto tech with L1. I have a 88 Z24 pickup myself. I'm in the prosses of looking for rebuilt injectors. New ones cost 240-290$ each!
Tuesday, January 4th, 2011 AT 2:16 PM
DIETZ336
Will the injector problem also apply to the V-6? Mine was only having a surging issue at idle and it normally does it when it is cold (under 30degrees f) however it’s happening on acceleration and even after the engine warms up.
Thanks for any insight.
Friday, December 13th, 2019 AT 1:54 PM
STEVE W.
  • 13,465 POSTS
Which year? The 88/89 3.0 uses a TBI injection system that can act up if the injectors start to age. The easiest repair is to just replace the injectors. They also can have issues around the idle air control unit. That can be tested using a quick spray of carb cleaner at the IAC seal areas, if the engine rpm changes the seals are stiff and failing.
Tuesday, December 17th, 2019 AT 12:04 PM
